Electrical problem
2000 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic
Dear Sir,
Good Day,
Hope you doing well...
I have problem with my Alero 2000, the problem with the Fuel Pump and the details as follow....
Fuel pump doesn't work, but when i give it 12V from the Battery i found it working i checked the fuse board I found fuse # 48 (F/P INJR) fired,I changed it, but the fuel pump still not working
Also I switched relay# 18 with relay# 21, but the fuel pump still not working when connect it in its place! I
Also I did this test and I have these results:
1) Red lead of the Multimeter in the positive of the battery, Black lead of the Multimeter in the Pin#30
A) When the key off, Multimeter read 12.49Volts
B) When the key on, Multimeter read 0.01Volts
2)Red lead of the Multimeter in the positive of the battery, Black lead of the Multimeter in the Pin#85
B) When the key on, Multimeter read 12.25Volts
Please what is the problem?
please help
Warm regards,
Qussay AlObiedy
Dear Sir,
Good Day,
please help
Warm regards,
Qussay AlObiedy
Apr 9, 2010 at 9:35 AM
