2000 Oldsmobile Alero blower motor not blowing
2000 OLDSMOBILE ALERO
127,000 MILES • 6 CYL • FWD • AUTOMATIC
NO124FAN
been 2 days w/o heat, no blower. i pulled the motor, hooked it up direct 12v, it works fine, i replaced the resistor, still no blower, i checked all three fuse panels, replaced 1- 30 amp fuse under the hood, still no blower. still feel the heat emminating from defrost, but no blow. also i can hear an audible click when i switch on the blower on the dash.
Dec 15, 2009 at 11:20 AM
BLUELIGHTNIN6
  • 16,542 POSTS
you need to replace the blower motor relay. that is the "click" you hear. it is located in the underhood junction block.
Dec 15, 2009 at 2:07 PM
