1999 Oldsmobile Alero Problems with Blower Motor
1999 OLDSMOBILE ALERO
BIGSTAFF00
Heater problem
1999 Oldsmobile Alero 4 cyl Two Wheel Drive Automatic
I replaced the blower motor, resistor, fuses and relay for the heater in this car. After all this, it will only run on high speed and not on the other 5 lower settings. What else could be wrong?
Dec 12, 2009 at 4:41 PM
Check and test the blower control switch,also double check the resistor
Dec 12, 2009 at 4:50 PM
I want you to check for power at the resistor dark blue wire -turn the heater on and get back with me.
Dec 12, 2009 at 5:18 PM
