1999 Oldsmobile Alero Gas Leak
1999 OLDSMOBILE ALERO
163,183 MILES • 6 CYL • FWD • AUTOMATIC
RAISHUNBRUC
My car has a gas leak in the front and I'm trying to figure out what could be causing it and how do I go about fixing it
Dec 19, 2008 at 1:42 PM
Hi:
Start at the fuel line (near the fuel filter) and work forward till you get to the fuel rail. From that point follow the rail to each injector and make sure there are no leaks along the rail and inspect each fuel injector where it mounts to the motor. They have O-rings that are a common problem. NOTE: Any fuel leak is a potential fire hazard. Let me know if this helps so I know what to tell you next.
Merry Christmas,
Dec 21, 2008 at 9:05 PM
