1999 Oldsmobile Alero gas dumping out of exhaust
1999 OLDSMOBILE ALERO
TE1971
Engine Mechanical problem
1999 Oldsmobile Alero 4 cyl Front Wheel Drive Automatic
my car started to get a skip the check engine light came on so i scaned it multipail missfire and running to ritch thought it was catylac converter because it was glowing cherry red i bord out the cat and it still glowing red now car will not start and fuel is dumping out of exhaust what could it be
thank you
Jan 26, 2009 at 4:12 PM
MHPAUTOS
  • 31,937 POSTS
HI there,
Thank you for the donation,
I would be getting a fuel rail pressure test done and checking for leaking injectors, a pintal may of failed and fuel is flooding the engine, start here.
mark (mhpautos)
Jan 27, 2009 at 4:58 AM
