Relieve the fuel system pressure.
Remove or disconnect the following:
Fuel line from the filter, using a backup wrench
Quick-connect fitting from the fuel filter by compressing the tabs while pulling outward on the line
Fuel filter from the mounting bracket
Install or connect the following:
Fuel filter to the mounting bracket
Fuel line using a backup wrench.
Torque the fitting to 20 ft. lbs. (27 Nm).
Quick-connect fitting to the fuel filter
Negative battery cable
Pressurize the fuel system and verify no leaks.
Dec 22, 2009 at 12:37 PM
