i recently have been having overheating problems with my 99 oldsmobile alero with the 3.4 v6 engine. i have changed the thermostat, radiator,waterpump, all of the hoses, the overflow resovoir cap, . the fans work, the car overheats as you drive it really soon, when this occurs i pull the upper hose on the thermostat housing and oly steam comes out instead of coolant, there is no white smoke from the exhaust and the oil stays clear and clean. the heater does'nt blow hot air either. do you have any suggestion as to what the remody to cure this would be? thank you.
Apr 30, 2009 at 10:32 PM
