1999 Oldsmobile Alero Antilock light
1999 OLDSMOBILE ALERO
118,000 MILES • 6 CYL • FWD • AUTOMATIC
STRING TWISTER
  • 4 POSTS
I never had a problem with the abs or traction system on the car-I just changed right front hub bearing and now the light comes on anytime from immediattly until up to 5 miles and stays on.
Apr 24, 2008 at 3:35 PM
MERLIN2021
  • 17,250 POSTS
Either the sensor or the ring gear(reluctor) was damaged...the ring if hit even by accident can be de-magnetized, and stop working! If you have a DVOM, you can test which one is bad, unplug the sensor at the end of the wire near the top of the sensor, read OHMs, they should be about, 088-1400 ohms, now switch the meter to read volts,, spin the wheel, and you should get a voltage reading, it will vary depending how fast you spin! No OHMs, bad sensor, no Volts, bad ring gear!
Apr 24, 2008 at 3:42 PM
STRING TWISTER
  • 4 POSTS
old one has 1.05 ohms resiestance and new has 1.44?
Apr 24, 2008 at 3:50 PM
STRING TWISTER
  • 4 POSTS
do I check for dc or ac voltage-it's pouring rain, I will follow up when it stops.
Apr 24, 2008 at 3:52 PM
MERLIN2021
  • 17,250 POSTS
Unfortunately I don't have access for the specs on your part, what I recommend, is have it scanned for ABS "C" codes, this seems to be the only way of checking it. If either one shows, since it's all integfral to the bearing, the whole part has to go! During the install did you hit it with a hammer?
Apr 24, 2008 at 3:56 PM
STRING TWISTER
  • 4 POSTS
I always have and did use a impact.-we just went to town and back and it gave no trouble. I scaned for codes and came up with nothing-I am not sure that my obd2 does abs though.
Apr 24, 2008 at 5:48 PM
MERLIN2021
  • 17,250 POSTS
If you have a scanner from Actron, I don't think it does ABS, usually these type cast close to 1000.00!
Apr 25, 2008 at 2:26 AM
