1999 Oldsmobile Achieva My only car I drive my infant to da
1999 OLDSMOBILE ACHIEVA
104,211 MILES • 4 CYL • 2WD • AUTOMATIC
SWEETPARRIS2
At times when the car is idle at a stop light it will have a slight hesitation/skip/jerk and the RPM will drop very slightly then immediatly go back to normal. While it is parked in the driveway if I rev the RPMs pass 2K and let off the gas and let the RPMs drop back to normal it will drop below 500 RPMs and act like it will stall and the interior lights will go dim for a second before it jumps to its normal operating RPM. On the highway if I am driving above 45 mph and at around 2K RPMs and let off the gas then press the gas slightly to accelerate it will hesitate and buck, the RPMs again drop slightly but will grab and go after a few seconds of this hesitation. Normal street driving the car will hesitate/skip/buck/jerk when I apply light gas pressure to accelerate (it will hesitate, jerk etc. around 2k RPM) Driving uphill at 2k RPM it does the same thing only the hesitation, jerking is much more noticable. I've taken the car to multiple repair shops and have had the spark plugs replaced, boot to ignition coil replaced, coils replaced. I also had injector cleaner and fuel system cleaner, nothing has worked and repair shops have no clue what the problem is. Please help, I am a single mom and this is my only car I have, I drive my 6 mo baby in this car and I am worried that I will get stuck. I have no money to buy a new car and took out a loan to fix this one however no one can fix this problem. Any help is appreciated. Thank you!
Feb 25, 2009 at 9:17 AM
BILLYMAC
  • 2,204 POSTS
hi and thank you for doing your homework all the info you gave us will certainly help.i noticed although a lot of parts were replaced no mention of module or fuel pump.was these two things tested.if not they should be.bear with us if we don,t find the prob the first time .we will there is a lot of great techs here on this site and they will all try and help so let me know the answers to my question and we will work on this prob,thanks billymac
Feb 28, 2009 at 8:28 PM
HELPING YOU
  • 100 POSTS
Hi, It does sound like ignition prob. I'm going to assume they've found fuel pressure good while fault's occurring or they wouldn't have replaced the (expensive) coils.
You may want to try a shop with factory info available - the "dealership" has equipment, software, and resources unavailable in the aftermarket. (ie; diagnostic tools ,computer tests, engineers' "hot line", and technicians' forums - like this one - exclusive to the manufacturer.
Feb 28, 2009 at 9:05 PM
