1998 Oldsmobile Achieva Heater core?
1998 OLDSMOBILE ACHIEVA
12,900 MILES • 6 CYL • 2WD • AUTOMATIC
MEADOWMAN77
My car, last evening while driving home from a nearby town..started making steam and hissing noises,..soon to be followed by steam coming into my drivers compartment.(and leaving a stream of steam in a narrow straight band straight up the center of my interior windsheild). No warning light came on..and the heat guage was not overheated but withen upper normal range. I travelled probably a mile before pulling into my Garage. I shut off the car and found the steaming sound ended after 2-3 minutes. There was a watery smell in the air, and found a puddlle of antfreeze under the car. The next morning removed radiator reservoir cap..found the level very low.. and added a full gallon of anti-freeze. It began to immediately poor out just past the front wheel..( but a foot or more towards the center of undercarriage). it seemed to be pouring out from 4 ponts closely grouped in a seeming straight line. The radiator did not appear to be leaking at all..in fact had it flushed and thermostat replaced about 5 weeks ago. I had the motor turned off when adding coolant,..thought I'd add that bit of info. I had just been running the air conditioner just before the incident. I thought it might be the water pump? But when I phoned local garage, he suggested it sounded like heater core. This is the very first time I had these symptoms..and wondered what you all thought? I have a '98 Olds achieva SL, 6 cylinder motor. P.S. Had a mechanic flush radiator and replace thermostat one month ago..did they somehow cause this?
Jun 30, 2010 at 7:46 PM
RICHZOMBIE
  • 173 POSTS
It sounds like your local mechanic is right. If it were the water pump it shouldn't be able to cause water or steam to come into the driver's compartment. You should have someone check the heater core.
Jun 30, 2010 at 8:18 PM
