1998 Oldsmobile Achieva Car Won't Crank
1998 OLDSMOBILE ACHIEVA
188,690 MILES • 6 CYL • 2WD • AUTOMATIC
ADOZIER83
Car won't crank "security" light is on (solid-no blinking).
Hist: Car has had ignition (column) problems for mo will start but wll nt consistently turn off. Driver must move key and manually turn ignition off.
Raditor cracked removed and disconnected battery and installed another reconnected battery.
Car won't crank "security" light is on (solid-no blinking). Undidd batt left overnight reconnected no crank. Researched Pass Lock issues left in ky in "on" position for 20min no crank.
Please help.
Oct 2, 2010 at 7:26 PM
I hate to say it, but it needs to go to a dealer. They are the only ones that have the proper test equipment to check the security system.
Oct 25, 2010 at 4:07 PM
