1996 Oldsmobile Achieva Starting
1996 OLDSMOBILE ACHIEVA
Electrical problem
1996 Oldsmobile Achieva 6 cyl Automatic 130000 miles
When have to hit the ignition 3-5 times.....let it sit for 10-15 minutes and then it starts. We have replaced the starter, relays and ignition. It seems to have something to do with the key. If we do not turn the key completely off, it will restart easily. If we shut it completely off it takes several attempts, letting it sit and then it starts.
Jan 22, 2010 at 6:01 PM
Chances are you have a bad ignition switch. However, I would recommend checking fuel pump pressure prior to replacing the pump. If you need directions, let me know.
JOe
Apr 6, 2010 at 10:43 AM
