1996 Oldsmobile Achieva no start
1996 OLDSMOBILE ACHIEVA
VARGAS
Electrical problem
1996 Oldsmobile Achieva 4 cyl Automatic 75,000 miles
drove vehicle home and let it idle for a while and turned it off for about 20 minutes and then it wouldn't re-start. security light started flashing?
Dec 19, 2008 at 7:46 PM
HI:
Does the key have an resister in it? If so, try a different key. If that doesn't help, the problem is most likely with the sensor in the steering column. It will require special testers to check it. Most likely, a dealer will be the only place to find the test equipment.
Dec 20, 2008 at 11:54 PM
