What is making the engine idle so high? Its idling between 1,500 to 2,500 RPMS ...I know u cant adjust the idle so what could be the problem ?
Jun 5, 2010 at 7:33 PM
CERTIFIED EXPERT
Clean out the idle air control valve.
Jun 5, 2010 at 8:08 PM
OSUFAN10
MEMBER
Where is it located? And what should I clean it with?
Jun 5, 2010 at 8:24 PM
CERTIFIED EXPERT
Its on the throttle body and use a carb cleaner
Jun 5, 2010 at 9:23 PM
OSUFAN10
MEMBER
Replaced the valve...still idles above 2000 RPMS
Jun 6, 2010 at 10:17 AM
CERTIFIED EXPERT
Check the ignition timing, also for a vacuum leak or try adjusting from the throttle stop screw and also clean the throttle plate bore or kinked/binding acc. cable
Jun 6, 2010 at 2:09 PM
OSUFAN10
MEMBER
problem fixed...disconnected battery and reconnected it..that reset the computer...idles great now
