Brakes problem
1994 Oldsmobile Achieva 6 cyl Front Wheel Drive Automatic
I had the 2 rear brake lines replaced with new wheel brake cylinders and pads , followed the proper bleed procedures for abs .I now have a left rear brake that continues the lock up under med. to heavy breaking.
my machanic thinks that when my rear line failed it jamed the abs system . is there a way to reset the abs proportioning valve. thank you
Nov 21, 2008 at 11:40 AM
