1992 Oldsmobile 98 No crank
1992 OLDSMOBILE 98
JAY GREAVES
Engine Mechanical problem
1992 Oldsmobile 98 6 cyl Front Wheel Drive Automatic
I have a no click or crank situation. I have replaced the starter and solenoid. I am good at the battery. The ignition switch powers up and goes off when engaged like it should. The starter will turn over if jumped at the solenoid. I have checked all the fuses.
Jul 20, 2010 at 2:32 AM
Your probable causes here could be one of the following the park/neutral position switch, starter enable relay and ignition switch
Jul 20, 2010 at 4:00 AM
