1991 Oldsmobile 98 transmission filter
1991 OLDSMOBILE 98
168,000 MILES • 6 CYL • FWD • AUTOMATIC
JPOTT123
Do you have to use the small plastic bushing that comes with the new filter?
Feb 27, 2010 at 1:37 PM
BLUELIGHTNIN6
  • 16,542 POSTS
when replacing tranny filter just drain pan, discard old gasket, remove filter and "O" ring or sleeve type seal. clean pan, magnet and screen. install a new "O" ring on the pick-up tube or a new sleeve into the pick-up tube recess. install new filter assembly then install oil pan and refill.
Feb 27, 2010 at 4:50 PM
JPOTT123
[quote:e446eee78c="bluelightnin6"]when replacing tranny filter just drain pan, discard old gasket, remove filter and "O" ring or sleeve type seal. clean pan, magnet and screen. install a new "O" ring on the pick-up tube or a new sleeve into the pick-up tube recess. install new filter assembly then install oil pan and refill.[/quote:e446eee78c] Thanks ,I didn't realize the bushing was actually a sleeve seal .I wanted to flush the system anyway because the oil was quite dark so I'll drop the pan and install new seal.
Feb 27, 2010 at 7:17 PM
