The car starts fine and runs fine until it warms up and goes into closed loop mode. Then it does not shut off but chugs, surges, pauses, runs rough. It started out minor and now is getting worse.
What I have replaced so far:
Plugs, wires, EGR, IAC valve, Ignition control module and coils, fuel filter, O2 sensor.
About 2 years ago the dealer put in a remanfactured ECM assembly.
I cleaned the throttle body and checked for vacuum leaks and bad hoses. I checked the fuel pressure and it runs steady at 35psi (within spec).
I am suspecting a bad catalitic converter or maybe it's the Crank or Cam position sensors. What do you think??
May 31, 2009 at 7:38 AM
