After warmup the engine runs rough, chugs, surges and pauses
1989 OLDSMOBILE 98
168,000 MILES • 6 CYL • FWD • AUTOMATIC
MLANTZ
  • 4 POSTS
The car starts fine and runs fine until it warms up and goes into closed loop mode. Then it does not shut off but chugs, surges, pauses, runs rough. It started out minor and now is getting worse.
What I have replaced so far:
Plugs, wires, EGR, IAC valve, Ignition control module and coils, fuel filter, O2 sensor.
About 2 years ago the dealer put in a remanfactured ECM assembly.
I cleaned the throttle body and checked for vacuum leaks and bad hoses. I checked the fuel pressure and it runs steady at 35psi (within spec).
I am suspecting a bad catalitic converter or maybe it's the Crank or Cam position sensors. What do you think??
May 31, 2009 at 7:38 AM
RACEFAN966
  • 5,029 POSTS
Okay, I would like you to check the coolant temperature sensor. If you could unplug it and do an ohms reading on the sensor (not wire harness). If you do this cold then get back to me with reading and what setting it was on and the air temp at the time of the test. Then get it warmed up when it is having its problems and do the test again this time provide the reading the engine temp. Thanks.
Jun 1, 2009 at 9:52 AM
MLANTZ
  • 4 POSTS
Since it was hard to get to I just installed a new one. It read ~2.1K at 85deg F. Did not solve problem. Also, I have yet to get a fault code. I even tested the system by disconnecting the TPS and it set code 22 correctly. On Sunday I drove it 20 miles in city and hwy with no problem. I then stopped and shut it down for 5 min. When it started it immediately started cutting out and did so all the way home. Really a puzzle. I suspected bad gas but all the samples I took from the fuel rail are fine. Why no codes???
Jun 1, 2009 at 6:51 PM
RACEFAN966
  • 5,029 POSTS
Okay, I would like you to do the same test on the air charge temperature sensor. This sensor is in the air intake tube should be easy to get to. You do the test just as you did the coolant sensor. Let me know what you find ok. Thanks.
Jun 2, 2009 at 10:38 AM
MLANTZ
  • 4 POSTS
It appears to be okay. also, 1745ohms at 105 deg and 960 ohms at 135deg (I checked the actual temperature with a laser temperaturetemp.
Jun 2, 2009 at 6:52 PM
RACEFAN966
  • 5,029 POSTS
Okay, I would like to check the cam and or crank sensor. But I need to know what engine you have as the 3.3 the sensor does both and the 3.8 ltr they are seperate sensors. Get back to me and we will take it from there.
Jun 3, 2009 at 10:48 AM
MLANTZ
  • 4 POSTS
This model only used the 3800 engine. I thought about these but since they are a required signal for the spark and the engine runs fine cold I assume these are okay. I don't have the diagonstic equipment to read the pulse signals, is there an easier way?
Jun 3, 2009 at 5:53 PM
RACEFAN966
  • 5,029 POSTS
Okay, lets run some tests on the camshaft sensor. Now what I have read the car will run if the signal is bad just not well. It is on the timing cover refure to pic below. Now here is what I need you to do first. Unplug it and hook up your volt meter (on the plug) between term a and b and check voltage and then check voltage between term b and c with key on engine off votage should be between 8-11 volts. Let me know what you find. Also is the engine light on and is there any codes? The first pic below is so you can locate the camshaft sensor. The second pic is so you know what term is what in the sensor harnes so you can test the voltage, if you look in the lower right hand corner of that pic you will see the camshaft sensor plug with the term labeled let me know what you find.
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic_88.jpg
https://www.2carpros.com/forum/automotive_pictures/249564_Graphic1_13.jpg
Jun 4, 2009 at 10:21 AM
TAZZ ZEROLIMITZMC PAGE
Hi, I just saw this post and wondering if the issue was ever solved i know it has been since 2009 speaking of it. but I have one now that's doing the same issue. was wondering if mlantz ever fixed the issue to the 1989 oldsmobile 98. please Let me know thanks .
Jun 16, 2020 at 7:59 PM
There are times we never get the results of whether it worked or not.
No news is good news could apply.
If you have a question, feel free o start a new question and we will be glad to help you.
Jun 17, 2020 at 5:45 AM
RENEE L
  • 1,260 POSTS
Hello TAZZ ZEROLIMITZMC PAGE ,
Here is the link to post your question: https://www.2carpros.com/questions/new
Make sure you are logged into the site before clicking on the link.
One of our experts will be more than happy to help you.
Thank you for using 2CarPros and have a great rest of your day!
Renee
Admin
Jun 17, 2020 at 2:11 PM
Thank you guys.
Jun 18, 2020 at 8:26 AM
