1988 Oldsmobile 98 brake lights
1988 OLDSMOBILE 98
300,000 MILES • 6 CYL • FWD • AUTOMATIC
CHRIS1966
how do you take apart the tail light frame to change
the brake light bulb? also the reverse light frame?
Mar 5, 2010 at 3:09 PM
Open the trunk and remove the carpet near the rear tail light assembly. Under the carpet, you will see 3 or 4 whing nuts that hold the light in place. Remove them and the entire assembly will come out and then you will have access to the bulbs.
Apr 15, 2010 at 12:23 PM
