Replaced motor, Has about 80 miles on it. all components except throttle body fuel pump and fuel rail harness. No codes on check engine except normal 1-2. Once accelerated it runs good, lots of power.My shop mechanic can't figure out the problem and he is a very good mechanic. I have all the shop manuals for it.Could a dirty sock on the fuel pump or pulsator be causing the problem? Also replaced some of the firewall relays . Also where can I get a Dorman replacement fuel injection wire harness? Your list does not go down to 1985 Thanks, Chaz
Nov 17, 2009 at 10:01 PM
