1980 Oldsmobile 98
1980 OLDSMOBILE 98
190,000 MILES • V8 • 2WD • AUTOMATIC
LILTRISAC
How do u change fuel pump?
Sep 21, 2010 at 1:13 PM
First, disconnect the battery. Next, disconnect the supply and return fuel lines from the pump. Have a bolt or something to plug the supply line so you don't lose the fuel from the tank. Next, there are two bolts holding the pump on the side of the engine block. Remove it and reinstall the new pump in the reverse orderr.
Nov 5, 2010 at 12:08 PM
