Went through all the steps for testing ignition. last problem arrived at checking voltage at crank sensor on terminals a and c
should be 9 to 12 mines 5 volts 2nd tried voltage reading at a to ground 5 volts again supposed to be 9 to 12. Doubled check power inputs on pink/black wire 12 volts even tried direct 12 to that wire. replaced module and coil pack same situation any help would be appreciated. Fuel pressure at 45. steps taken were from on demand software
Dec 10, 2008 at 5:25 PM
