when car starts windows work while the car is on i play with the window switch and it cuts off... check all fuses still puzzled... can u help me
Jun 30, 2009 at 6:57 PM
CERTIFIED EXPERT
WHat you need to do is when it doesn't work, you need to remove the door panel and check if the motor is getting power. IF it is, the motor is the problem. If there is no power, chances are the switch is the problem.
