ive replaced the battery and starter. the are both in working condition. i've use a 225amp battery charger set on start mode. the only results i keep getting is the floating starter gear(which is supposed to engage w/ the flywheel) only slams into the flywheel. it will not engage, therefore it is unable to perform its primary job of turning the flywheel. even though the original starter did not have shims i shimmed it. and that did not work either.. can you guys please give me some more advice, because believe me i've been getting alot from everybody i know.
Dec 8, 2009 at 6:04 PM
