1996 Oldsmobile 88 air
1996 OLDSMOBILE 88
MONEEKA
Air Conditioning problem
1996 Oldsmobile 88 Automatic 170000 miles
When I try to operate the air conditioning, it only blows air for defrost and no other vents..
Jun 12, 2010 at 9:14 PM
In this case, you are looking for a vacuum leak. The air flow is determined by vent doors in the HVAC system. If the vacuum pressure isn there to move them, it goes to a default, the defroster.
Check under the dash for leaks. If you are lucky, you may hear a hissing sound where the leak is with the engine running.
Aug 13, 2010 at 9:47 PM
