1995 Oldsmobile 88 bolt size on brake light assembly
1995 OLDSMOBILE 88
FIBBOMARCH
  • 8 POSTS
1995 Oldsmobile 88 80000 miles
I need to know the bolt size on the brake light mounting. I tried an m6 as that seemed to match in the parts store but the fit is too loose. I had one miscellaneous bolt I found that fits perfectly. This is the bolt that screws into the brake assembly that mounts to the tail light bracket.
Apr 3, 2010 at 2:50 PM
2CARPRO JACK
  • 11,533 POSTS
Imnot sure exactly which bolt you are describing, but for most GM vehicles, you will need a 1/4 standard or 5.5mm, 7mm,8mm 10mm for the interior screws,bolts
Apr 4, 2010 at 9:47 AM
FIBBOMARCH
  • 8 POSTS
[quote:49a4b741ed="2CarPros Jack"]Imnot sure exactly which bolt you are describing, but for most GM vehicles, you will need a 1/4 standard or 5.5mm, 7mm,8mm 10mm for the interior screws,bolts[/quote:49a4b741ed]
Good answer I tried 6 mm too small even though the old bolt fit the 6mm template at the parts place, I get some 7mm and try those although I thought I tried those. maybe not. 8 mm are definitely too big. I will have to look around since finding 7mm has been tough in a city of over 1 million people!
Apr 4, 2010 at 10:04 AM
2CARPRO JACK
  • 11,533 POSTS
Then it may be 1/4 or 5.5 mm
Apr 4, 2010 at 10:14 AM
FIBBOMARCH
  • 8 POSTS
[quote:fecfb646d2="2CarPros Jack"]Then it may be 1/4 or 5.5 mm[/quote:fecfb646d2]
5.5mm would definitely be too small
Apr 4, 2010 at 10:41 AM
2CARPRO JACK
  • 11,533 POSTS
Try 1/4. To this day they still mix up standard and metric on interior and trim parrts
Apr 4, 2010 at 12:32 PM
MOTORHEDGE
7mm or 9/64 are common on GM auto's, usually tail lights are fastened with 10mm metal speed nuts.
Dec 25, 2010 at 5:56 AM
