1995 Oldsmobile 88
1995 OLDSMOBILE 88
169,500 MILES • 6 CYL • FWD • AUTOMATIC
TANYA ROBEY
what would make a car over heat if there is coolant in it a new thermostat
Nov 4, 2008 at 7:26 PM
LEGITIMATE007
  • 5,121 POSTS
you can check your engine coolant temperature sensor, if that is not the problem then you may need to replace your radiator because it may be plugged
Nov 4, 2008 at 8:12 PM
