Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Oldsmobile
88
Engine
Symptoms
Overheat
1995 Oldsmobile 88
1995 OLDSMOBILE 88
169,500 MILES • 6 CYL • FWD • AUTOMATIC
TANYA ROBEY
MEMBER
1 POST
FOLLOW
what would make a car over heat if there is coolant in it a new thermostat
Nov 4, 2008 at 7:26 PM
LEGITIMATE007
CERTIFIED EXPERT
you can check your engine coolant temperature sensor, if that is not the problem then you may need to replace your radiator because it may be plugged
Nov 4, 2008 at 8:12 PM
