1991 Oldsmobile 88 seal belt buckel-weak spring on push but
1991 OLDSMOBILE 88
TRAPDOOR
Interior problem
1991 Oldsmobile 88 Two Wheel Drive Automatic 191000 miles
Passender and Driver side cona use seal belt. The latch is wider than the middle seat beal so you cant use it. I need to be able to repair the original. How to get apart. No junk yard here and suto upplies don;t had it. YEs I can mai off for $ 50 aperace and get repaired. Need sooner and cheaper. Their has to be a spring or kit at the reair folks can get them-so shoul i be able to.???
Sep 13, 2010 at 12:09 PM
They are not designed to be repaired. Because it is a safety component, I recommend replacement.
Oct 24, 2010 at 11:14 PM
