1991 Oldsmobile 88 Rotor Nut
1991 OLDSMOBILE 88
85,000 MILES • 6 CYL • FWD • AUTOMATIC
PYROKMG
I have a 1991 Oldsmobile 88 royale, and I am in the process of changing my rotors. I don't have a wrench big enough right now. I need to know what wrench I should use to take them off.
Thanks, Kevin
Sep 23, 2009 at 11:14 AM
HMAC300
  • 48,601 POSTS
if you are talking about the large nut in the center, that is the nut that holds the axle to the wheel bearing. You need to take the caliper bracket off to get the rotor off, not the large nut in the middle.
Nov 11, 2009 at 7:19 PM
