1990 Oldsmobile 88 No air from vents in oldsmobile delta 88
1990 OLDSMOBILE 88
15,200 MILES • 6 CYL • FWD • AUTOMATIC
JOCEY79
I was wondering, I am not getting air blowing from my vents at all. I checked the fuses for the a/c and the fans and they are fine. I beleive the a/c is kicking on but just the fans are not working. What could cause this?
Jul 15, 2010 at 7:37 PM
It could be a few things. Have you checked to see if there is power to the blower motor? If there is, it is most likely bad.
Aug 13, 2010 at 9:29 PM
MIKE32886
[quote:0cf471feef="Jacobandnickolas"]It could be a few things. Have you checked to see if there is power to the blower motor? If there is, it is most likely bad.
Joe[/quote:0cf471feef] how can you check to see if there is power to the blower motor i have the same exact problem
Aug 15, 2010 at 4:31 PM
The blower motor under the hood, passenger side, rear engine area, upper firewall, mounted in relay panel Locate it, unplug the wiring to it and using a test light, turn the power on to it to see if it lights up. The higher speed you select, the brighter the light should get. You can also do this with a volt meter. Here is a picture of it.
https://www.2carpros.com/forum/automotive_pictures/249084_5_45.jpg
Let me know if you have questions. Joe
Aug 15, 2010 at 10:13 PM
