Engine light will not stay off
1988 OLDSMOBILE 88
89,000 MILES • 4 CYL • FWD • AUTOMATIC
AUDREY821
engine light will not stay off when on motor runs rough?
Oct 6, 2009 at 11:47 AM
SQM
  • 6,383 POSTS
The engine can run rough due to a number of reasons.
It could be for a vacuum leak, worn spark plugs, weak fuel pump, dirty fuel filter etc.
Inspect the spark plugs for gap and ware. Also check for any vacuum leak. You could have a vacuum leak from any of the vacuum hoses. Look for any cracked or broken hoses.
Since the check engine light is illuminated, the best course of action would be to retrieve the trouble code(s). This can help with the diagnostics.
Here is a helpful guide on code retrieval and the code details:
https://www.2carpros.com/articles/buick-cadillac-chevy-gmc-oldsmobile-pontiac-gm-1983-1995-obd1-code-definitions-and-retrieval-method
Please let me know what code(s) you get.
Thank you.
Dec 13, 2021 at 10:29 PM
