1984 Oldsmobile 88 Baro sensor Location
1984 OLDSMOBILE 88
EFIL4NAMKCALB
Computer problem
1984 Oldsmobile 88 V8 Two Wheel Drive Automatic n/a miles
Code 32 is barometric pressure sensor low output. Is there a way to solve this problem? If I need to change it where is it located? What effect does it have on driveabillty? Is there a diagram that shows where all the sensors are located ? please help thanks.
Nov 14, 2009 at 2:09 PM
MERLIN2021
  • 17,250 POSTS
32 is EGR or MAP sensor voltage low, could be either, check for stuck egr, or carbon deposits holding pintle open, check vacuum source for bothe EGR and MAP sensors.
https://www.2carpros.com/forum/automotive_pictures/62217_Baro_1.jpg
https://www.2carpros.com/forum/automotive_pictures/62217_MAP_2.jpg
And is yours rear wheel or front wheel drive?
Nov 15, 2009 at 3:33 PM
EFIL4NAMKCALB
The car that I asked about Is a V8 With a carburated engine .I checked that area and didn't see it and it is rear wheel drive.
Nov 16, 2009 at 11:14 AM
MERLIN2021
  • 17,250 POSTS
On yours, the code 32 is for the EGR, not fuel injected= no Baro!
Nov 16, 2009 at 4:59 PM
