shut off while driving
2009 PONTIAC G6
103,957 MILES • 2.4L • 4 CYL • AUTOMATIC
LINDSAY LOOMIS
Car started drove bout a mile and shut off while driving. Coasted into a parking lot. Went to start it, started up and shut off just as fast. Had this problem last year. After four times of going into the dealership they finally said it was the computer. New computer put in November 2017. Now this. Acting the same, but when I checked the oil it smells like gas. Oil was changed less then three hundred miles ago. Plugs were changed summer 2017.
Feb 12, 2018 at 10:31 AM
Good afternoon.
fuel in the oil comes from a couple of thing.
fuel pressure regulator.
injector not closing and allowing continuing fueling.
rich running condition.
Feb 12, 2018 at 1:14 PM
There is a power train control relay that powers the ignition coils for you car which I think has gone bad but we should run the codes first.
If no codes come up lets test the relay.
Also check all fuses.
Check out the diagrams (below).
Please run some tests and get back to us.
Feb 12, 2018 at 2:47 PM
LINDSAY LOOMIS
Fuses are all good. No codes came up but I was not expecting any either. I have had this issue since September of last year. Every time it shuts off while driving (twenty five to fifty seven mph) and when it gets towed, no codes ever come up. When they replaced the computer in November we have not had a single problem until yesterday. After checking the relay (which was clean, looks new, lit up, clicked) it sat overnight. Went to try it this morning and it started up for about five seconds.
Feb 13, 2018 at 5:24 PM
Good morning.
The first thing I would do is check the fuel pressure. Need to be sure the pressure is correct.
you can rent a tester at a parts store is you do not have one.
Feb 14, 2018 at 12:30 AM
Here is a guide to help you see what you are in for when doing the job:
If the fuel pump fails it loses pressure causing the spray to be minimal which does not ignite this is where the fuel smell comes from.
Feb 14, 2018 at 10:21 AM
