Oil sensor light on? Sender?
2001 CHEVROLET CAVALIER
148,000 MILES • 2.0L • 4 CYL • FWD • AUTOMATIC
LUCKYCARL
  • 6 POSTS
My oil sensor light comes on when my car is stopped or idling and the engine is hot, but the engine is not over heating. As soon as I start driving again the light goes off. Checked the oil and it has the correct amount of oil and has never leaked any oil. I plan on getting the oil changed this weekend, as it is past due for this, hoping it might help. Just started happening the last few days. Any information would be helpful.
Jul 20, 2016 at 9:14 PM
CARADIODOC
  • 34,306 POSTS
The "Oil" warning light refers to low oil pressure, not level. If you are lucky, the sending unit may be defective. The oil pressure will go down at lower engine speeds. Forty pounds is normal. Most warning lights turn on at around ten pounds.
There are two other common causes of this symptom. The oil gets thinner when it is hot so it is easier to run out of the engine bearings. That makes it harder to keep the pressure up when the engine is pumping it at a low volume at low speeds.
The other cause is worn engine bearings. At the mileage you listed that really should not be a problem yet. If the problem persists after the oil change, your mechanic can check the actual pressure with a mechanical gauge.
Jul 20, 2016 at 9:42 PM
LUCKYCARL
  • 6 POSTS
I am going to change the oil myself, but I can barely get my hands on the filter from under the car. Do I need a special tools to take the filter off?
Jul 23, 2016 at 9:19 AM
CARADIODOC
  • 34,306 POSTS
Can't answer that exactly because I have to see where it is and the type and size. If it's the really small spin-on filter, you may be able to loosen it by hand, but GM isn't known for putting them where they're easy to get to. We used to be able to get a band-type filter wrench on almost any oil filter, but now it's common to have better luck with a cup-type tool that you turn with a ratchet. There's a lot of different sizes. You might find the right one by testing them on the new filter, and hopefully the old one will be the same.
Jul 23, 2016 at 8:42 PM
2CP-ARCHIVES
  • 4,540 POSTS
How do you change a oil sending unit on a chevy cavailar
Jul 21, 2020 at 2:20 PM (Merged)
JDL
  • 16,098 POSTS
These have two different engines so here are both locations below. The info I looked at was for 2.2L engine. The oil pressure switch is near the oil filter.
D69MTLHAIR
Engine Performance problem
2000 Chevy Cavalier 4 cyl Two Wheel Drive Automatic
my knock sensor on my cavalier went out and was leaking bad.i relpaced it and as soon as i started the car up to make sure it was good,another oil leak began flowing from another sensor in the same area...wtf? can you tell me what the name of it might be and why on earth another leak would spring from the same area except a different sensor? id like to know the name of what i need so i dont look like a dork at the auto store...
thanks
WRENCHTECH
  • 20,761 POSTS
Your knock sensor????
I don't think so. The knock goes into a blind hole and doesn't seal in anything. It can be completely removed without leaking anything.
If your talking about the oil pressure sender, then that should have solved your leak. I don't know what else you could be referring to unless you can post a picture of it.
JAY HASTY
How do i check the oil pressure switch?
Jul 21, 2020 at 2:21 PM (Merged)
JOHNNY G.JR
  • 320 POSTS
Ground the sensor wire going to it.
HMAC300
  • 48,601 POSTS
these work by grounding out the signal to make the gauge move it can also be your dash is in need of repair as they are digital and will do this. if switch is bad it will throw a code and most of time it is just replaced instead of testing.
SMALLBUTTOUGH89
Lately my oil light has been flicking on and off, but only when idle. It doesn't come on and stay on. I check to see if there was an oil leak and there wasn't. A guy at an auto part store said it could be my oil pressure switch going out.
Could that be the problem and where exactly is the oil pressure switch located in a 1997 Chevy Cavalier?
BLUELIGHTNIN6
  • 16,542 POSTS
Yes, a faulty engine oil pressure sensor could cause the light to illuminate as stated. However, it may also be a faulty oil pump.. The sensor is much cheaper of repair than pump so I would start with inspecting wiring to the sensor. Your vehicle's engine oil pressure sensor is located on left side of engine ( for pic. diagram post your engine size [2.2L or 2.4L ?] ).
Thanks for using 2CarPros.com!
SMALLBUTTOUGH89
The engine is a 2.2L
How do you know if the wiring is causing the problem?
BLUELIGHTNIN6
  • 16,542 POSTS
Just make sure the wiring is connected properly to sensor and inspect the wiring for damage (i.e. bare spots, burnt spots etc..).
https://www.2carpros.com/forum/automotive_pictures/261618_Noname_484.jpg
JAMIETACO
Im trying find pictures that show me where my oil pressure switch is and I cant find any to help the motor in my car is a 2.2 4cyl its a base model andi need help please send my pictures to help me locate it thank you
CARADIODOC
  • 34,306 POSTS
I can't get into the service manuals to look for a drawing, but the oil pressure sending unit will always be near the oil filter. It usually has two wires plugged into it.
MARKKRUIZENGA
Engine Mechanical problem
1996 Chevy Cavalier 4 cyl Front Wheel Drive Automatic
hello
can anyone tell me where i can find an oil pressure sending unit on a 1996 cavalier 2.2L motor? much appreciated
thanks
JDL
  • 16,098 POSTS
https://www.2carpros.com/forum/automotive_pictures/170934_chevy_cavalier_oil_pressure_switch_1.jpg
Hello, my info gave the above location. Toward driver side of engine.
TRUTHGIVER
Could you please tell me where the oil pressure sensor is located on this car?
JDL
  • 16,098 POSTS
My info showed this location, below.
TRUTHGIVER
Thank you very much JDL , much appreciated... : )
JDL
  • 16,098 POSTS
No problem, have a good day.
