Oil pump solenoid
2011 MINI COOPER
85,925 MILES • AUTOMATIC
YEBM
Mechanic ran a diagnostics and found:
- Oil pump solenoid internal failure, permanent fault.
- Valve cover gasket replacement - oil present in spark plugs tubes cylinder one coil oil damage.
My question is, which is more critical to get it fixed ASAP?
Jul 12, 2019 at 11:28 AM
SCGRANTURISMO
  • 4,897 POSTS
I would definitely get the issue with the oil pump fixed first. Without your engine's oil pump working, you don't have to worry about the second issue.
Thanks,
Alex
2CarPros
Jul 12, 2019 at 11:31 AM
YEBM
Thanks Alex! So it would make sense to get the oil pump fixed first and can wait a few weeks to replace the valve cover?
Jul 12, 2019 at 11:36 AM
SCGRANTURISMO
  • 4,897 POSTS
Hello again,
Absolutely, but the valve cover is probably leaking from the valve cover gasket, which you can replace really inexpesively. As a matter of fact you can do it with a $5.00 tube of RTV. The gasket itself shouldn't be more than $15.00 - $20.00 at your local auto parts store, and is about the easiest gasket to replace on your vehicle. We can give you instructions on how to do this if you wish. Please let us know.
Thanks,
Alex
2CarPros
Jul 12, 2019 at 2:57 PM
