I have a crank no start situation with my car and found out that the bolt that holds the oil pump gear to the shaft is broken and the gear is stuck to one side causing the outer rear timing balancer belt to stop rotating.
Could this be the reason why the car wound not start? if so, what would be the best way to fix it and hopefully have it run?
Thanks for your help.
Jul 19, 2020 at 4:53 PM
