Oil PSI
2002 OLDSMOBILE INTRIGUE
70,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
STUHRLING
  • 10 POSTS
Can the Oil Pressure (PSI) be read through the OBD2 port using and app like Torque Pro on a 2002 Oldsmobile intrigue?
I have tried different PID's and I either get nothing at all or some random number like -16.9. The Application does light up green as active but I still do not get anything.
Can Oil PSI be gotten through the OBD2 port on this vehicle?
Many Thanks for Any Help!
Jan 27, 2019 at 3:28 PM
KENW1
  • 213 POSTS
Thanks for visiting 2carpros.com. On this model the oil pressure switch receives 12 volts and supplies the ECM with an on or off signal. So, unfortunately , it will not provide an exact pressure reading through obd2. I'll post the wiring info below so you can see it.
Jan 27, 2019 at 5:40 PM
STUHRLING
  • 10 POSTS
Thank you so much! This is quite helpful!
All the best!
Jan 28, 2019 at 6:54 PM
You are welcome, KENW1 is one of our newest experts, he is quickly shaping up to be one of our best!
Feb 2, 2019 at 1:47 PM
