Oil pressure switch
1993 FORD ESCORT
93,000 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
MATTTYW20
  • 113 POSTS
I am looking to replace my oil pressure switch on my car listed above and I have not been able to find a video or a procedure on how to do it. if someone could help me out that would be great.
Sep 10, 2016 at 7:21 PM
CJ MEDEVAC
  • 11,004 POSTS
Can you find the location?
Here is what the switch looks like:
http://shop.advanceautoparts.com/p/carquest-by-bwd-oil-pressure-switch-s4363/10433389-P?searchTerm=oil+pressure+switch+socket
Some people pull them out with channel-lock pliers, you risk "egging" it and messing up its operation.
A regular socket will not fit it.
This is what you should use, it fits perfectly. Some of these are "stepped", the step will fit other sensors with the same design but have a different diameter. (useful on other repairs)
http://shop.advanceautoparts.com/p/autocraft-1-1-1-16-oil-sender-unit-socket-ac653/10051056-P?searchTerm=oil+pressure+switch+socket
The particular brand of sensor (first link) already has sealant on its threads.
No need to drain the oil, you may lose a little bit of oil (insignificant) when you take the old one out. (just so you might stick a rag under it to keep the driveway clean)
Start the new one in, insure it goes easy and is not cross threaded.
Tighten it good and snug. Do not get down on it with all your might.
Crank it up, get to operating temperature, look for drips or a leak, if it does, go a bit tighter.
easier to snug more if needed, than to get a broken sensor out of the engine.
This like changing the spark plug in your lawn mower/ weed eater!
Looks Good?
Hook the wire back on it.
Stick you with a fork, you are done!
Return with good news!
The Medic
Sep 10, 2016 at 9:00 PM
MATTTYW20
  • 113 POSTS
No, I have no clue where it is. I thought that it was on back side of block which is under the fuel rail which seems like a pain to get to then I thought someone said that you can acces it by taking the battery out and the battery tray. that is why I was looking for to be told what the whole removal process is. lol
Sep 10, 2016 at 11:29 PM
CJ MEDEVAC
  • 11,004 POSTS
Right side of the block, near the oil filter.
I was able to obtain you a component location diagram from "Prodemand".
This should be a really easy repair.
Post us as to your progress,
May the force be with you!
The Medic
Sep 11, 2016 at 10:54 AM
MATTTYW20
  • 113 POSTS
I tried getting the old one out today went to advanced and bought the socket but the socket doesn't seem to fit snug I've read online that some claim the starter is in the way but that doesn't seem to be it just the fact that the socket is not tight on sensor let me know wat you think thanks
Sep 14, 2016 at 6:06 PM
CJ MEDEVAC
  • 11,004 POSTS
Does it fit the new one snugly?
You do have an oil light not an oil gauge?
The tool is stepped for 2 different sizes, could it be you are on the bigger step and need to be on the smaller?
Reckon the old one was installed with pliers and they "egged" it? Now it won't slide into the socket?
The Medic
Sep 14, 2016 at 6:19 PM
MATTTYW20
  • 113 POSTS
The new one that I bought fits in there but it seems to have to go deep in there to fit it I bought the exact one you showed me at advanced I didn't know how it could be two sizes considering the ratchet end only fits in one side the of the pressure socket?
Sep 14, 2016 at 6:53 PM
MATTTYW20
  • 113 POSTS
And yes my oil light is on
Sep 14, 2016 at 6:54 PM
MATTTYW20
  • 113 POSTS
I feel like it has to go over the sensor more to snug but it can't cause the blocks there so idk can I jus turn the socket around?
Sep 14, 2016 at 6:55 PM
MATTTYW20
  • 113 POSTS
I think I'm gonna get an 11/16 socket tomorrow and see if that fits better
Sep 14, 2016 at 7:04 PM
MATTTYW20
  • 113 POSTS
A deep one of course
CJ MEDEVAC
  • 11,004 POSTS
This ain't your particular socket but similar
Got pic below off of the net, it was clear to see
Notice the 2 sizes at the open end of the socket (like a step), the socket will fit 2 different sensors.
I thought the one I suggested (I looked it up on their site) was the same as it said it would fit 1" and 1-1/16 (if either is the size of your sender)
The Medic
