Where is the oil pressure sensor or switch located?
2005 CHEVROLET UPLANDER
230,000 MILES • 4WD • AUTOMATIC
EMORPHEW1
MEMBER
1 POST
FOLLOW
Oil pressure sensor or switch needs to be replaced trying to locate the oil pressure sensor or switch.
Mar 6, 2024 at 12:06 PM
CERTIFIED EXPERT
The oil pressure sensor is on the left side of the engine to the rear of the A/C compressor. Here is the location and how to change it out in the images below, you may need a special socket to remove it. Check out the images (below). Let us know if you need anything else.
