I attached a picture of the location and the procedure for you.
Why are you replacing the sender?
Aug 11, 2020 at 12:11 PM
ROY JEFFREY CREEL
MEMBER
I am replacing the sender because of a "low oil pressure/turn off engine immediately" warning.. engine sounds fine. changed oil recently.. so I replace the filter again to make sure it wasn't a faulty filter.. warning came back after a week. I didn't hear anything strange or feel any difference while driving and after research saw that this could be the issue. Thanks so much for your quick response.
Aug 11, 2020 at 12:33 PM
CERTIFIED EXPERT
Change the sensor ans see if it stops. If it does not then you will need to have someone check the oil pressure manually with a gauge to be sure there is no issue.
