I am looking for the oil pressure sensor on my car listed above it has the v6. The engine oil light stays on so I want replace it.
Apr 25, 2017 at 7:59 PM
HMAC300
CERTIFIED EXPERT
see picture for location A/C compressor may be in way so check as picture is no accessories on it. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to enlarge)
Apr 26, 2017 at 7:04 AM
RMOELKE
MEMBER
Sometimes after car is driven for awhile, the oil light tries to flicker on.
May 17, 2019 at 7:38 PM
(Merged)
CERTIFIED EXPERT
Oil Pressure Switch (3.0L 2V)On right rear of engine block.
Oil Pressure Switch (3.0L 2V FFV)On right rear of engine block.
Oil Pressure Switch (3.0L 4V)On left front side of engine block
(Merged)
PHCLUB
MEMBER
where is the oil presure swith located and is this a simple replacement?
(Merged)
CERTIFIED EXPERT
It should be near the oil filter.
(Merged)
PHCLUB
MEMBER
[quote:a6fb1a240d="Jacobandnickolas"]It should be near the oil filter.[/quote:a6fb1a240d]
Thanks for the answer, I did find it on the top of the engine, on the right rear (facing from front), close to the firewall.
(Merged)
CERTIFIED EXPERT
I'm glad you found it. They like to make it easy to find things (LOL).
Take care and let us know if you have questions in the future.
