This could be the sensor but the proper way to test it is install an oil pressure gauge and monitor what the pressure actually is. However, there is a good chance it is the sensor because unless the oil pump is failing the oil pressure normally doesn't fluctuate very much. Because of this, I would understand if we just when ahead and replaced it to see if that solved the issue.
Let me know if you have questions and we can go from there.
Dec 12, 2019 at 4:40 PM
