Hi, my red oil light was coming on at idle. I changed the oil to see if that would make a difference. That I could tell, the van was not leaking oil, but during the change, I noticed it was about a quart low. The light still came after the change - sometimes solid, sometimes flickering. I self-diagnosed the problem and thought maybe it was just a bad oil pressure sensor. I bought a new aftermarket replacement sensor at a national chain and replaced the sensor. I thought maybe I had over torqued the sensor, so I backed it out a little bit and retorqued to specs. I started the engine, and everything looked good until I backed out of the garage and oil came pouring out under the vehicle. Hoping that it was just a bad sensor, I replaced it with a brand new one and the exact same thing happened. Help!
Apr 2, 2023 at 5:42 PM
