Where is the oil pressure sensor located?
2014 FORD ESCAPE
101,000 MILES • 1.6L • 3 CYL • 2WD • AUTOMATIC
GARY BOYER
oil pressure sensor location.
Nov 10, 2021 at 6:03 PM
On this engine, it is somewhat hidden behind the oil filter. To replace it, the oil filter will need to be removed, so this is a good time to change the oil.
If you look at pic 1, I attached a picture of its location after the oil filter has been removed. The remaining pics are from my manual that shows the procedure for replacement.
I hope this helps. Let me know if you have other questions or if I can help in any way.
See pics below.
Nov 10, 2021 at 8:53 PM
