oil pressure gauge not working properly
2005 GMC SIERRA
110,000 MILES • 5.3L • V8 • 4WD
JDOSKO
With the engine off or on my oil pressure gauge is maxed out to the right and does not move?
Nov 26, 2021 at 2:21 PM
This could be a couple of different things such as a bad sensor or even the instrument cluster.
Let's try a couple of things. First, locate the oil pressure sending unit on the back side of the engine behind the intake manifold. See pic 1 for location. Disconnect the sensor and see how the gauge reacts.
If there is no change, I need you to check pin 1 in the harness connector for continuity to ground. Also, pin 2 in the same connector should provide a 5v reference signal with the key on. Check that as well. See picture 2 below for pin orientation.
Here is a link you may find helpful when testing the wiring:
See pics below.
Nov 26, 2021 at 10:59 PM
