Oil pressure drops out
1997 INTERNATIONAL TRUCK
150,000 MILES • 7.3L
SWEETLEAF
  • 14 POSTS
Oil pressure is fine at idle, around 50 psi, but drops to 0 when revved up or going down the road.
Replaced the HPOP but still does it.
Nov 2, 2018 at 11:48 AM
HPOP? it sounds like you have a clogged oil pump pickup which happens. Can you remove the oil fill cap and look inside the engine using a flashlight to see how gunked the engine is?
Nov 4, 2018 at 11:13 AM
