Two main causes of low oil pressure are failing oil pump or excess clearance in the bearings. If the light is on all the time then we need to put a mechanical gauge on it to see what that says. If it shows low pressure as well then it is a mechanical issue and these would be the most likely cause.
However, if the gauge shows okay then more than likely you have a faulty sensor.
Here is a guide that gives a little more detail on these items. Let me know what the mechanical gauge says and we can go from there. Thanks
https://www.2carpros.com/articles/high-or-low-engine-oil-pressure
Oct 22, 2019 at 4:07 PM
