Oil Pressue Switch location and procedure
2005 FORD FREESTYLE
143,000 MILES • 3.0L • 6 CYL • 4WD • AUTOMATIC
WBURGOS
  • 4 POSTS
I want to know where is the oil pressure sender unit (switch) and how to replace.
Jan 2, 2016 at 7:26 AM
HMAC300
  • 48,601 POSTS
it unscrews like a bolt. under exhaust manifold see pic
Jan 2, 2016 at 9:38 AM
WBURGOS
  • 4 POSTS
Thanks, but I can't see it. Does any another cover or part need to be removed first?
Jan 2, 2016 at 5:58 PM
HMAC300
  • 48,601 POSTS
it may have a cover on it you probably wont' see it due to being UNDER EXhasust manifold feel around you'll find it
Jan 3, 2016 at 7:51 AM
WBURGOS
  • 4 POSTS
Thanks, at this time the light oil pressure low is not shows after several trips in meanwhile, Iam going to try to find it under exhaust manifold. In the freestyle is very hard to find it.
Jan 3, 2016 at 9:16 AM
HMAC300
  • 48,601 POSTS
look above oil filter
Jan 3, 2016 at 11:19 AM
WBURGOS
  • 4 POSTS
The only thing that I see is a cable near of oil filter and this cable go to oxygen sensor under oil filter but finish in the manifold.
Jan 3, 2016 at 5:33 PM
HMAC300
  • 48,601 POSTS
I can be of no further help then I've given you all the info on location.
Jan 4, 2016 at 6:58 AM
